2 members (Uncles51, Shardean), 50 guests, and 4 robots.
Topics128,021
Posts1,055,356
Members48,420
#586682 10/26/2009 1:34 PM
What do you all use for a headliner on the burbs and panels? I need something flexable enough for the curves on the sides. Any photos would be great.
Byronic #586760 10/26/2009 6:47 PM
GMONIZ #586763 10/26/2009 7:29 PM
Here is a photo album with comments of Jim Carter headliner installed on a 1954 Suburban.
Not all the pieces were cut properly.
I would do one thing differently: varnish/seal the back (upper) side of the cardboard.
The pieces bent into place fairly easily - two people working together made the job easier.
Here are a few photos of roof insulation that was installed prior to installing the headliner.
Tim
Byronic #586847 10/27/2009 1:33 AM
Thanks for the input. What would a fella use on a low budget. I saw 1/8 inch paneling at lowes. Could that be used and could you apply fabric to it? Sorry for too many questions in one sentence.My build is for a 66 panel. Thanks again.
Byronic #587162 10/28/2009 12:13 AM
you can get frp panels, 4 x 8 fiberglass about 1/16 thk at lowes or h.d. one side textured one side smooth.
DThela #588226 10/31/2009 3:02 AM
Thanks DThela, I use this at work at least once a month. Every time I install it I think, headliner?
