8 members (55shaker, baldeagle, Otto Skorzeny, JW51, 68ironhead, Ol'55, 3B, 1 invisible),
80
Mod | | | Forums66 Topics128,039 Posts1,055,473 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2009 Posts: 12 New Guy | | New Guy Joined: Oct 2009 Posts: 12 | Can anyone please tell me how to get the old motor an tranny out? So fare I have the motor mounts loose,all wires,gass line,carb links,even the 4 bolts on the back of the tranny where it is connected to the drive shaft tube.motor and tranny are still to gether,would like to pull together if possible.also have the fenders and hood off of the 54.it slides forword about 3" but will not come out!!PLEASE someone tell me what I am over looking!
you'll have that from time to time!!!
| | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | If you wish to remove the engine and transmission together as one unit first remove the cab.
Otherwise remove the transmission, then remove the engine.
Grigg | | | | | Joined: Feb 2006 Posts: 649 'Bolter | | 'Bolter Joined: Feb 2006 Posts: 649 | You don't have to remove the cab! After removing the 4 bolts on the torque tube is there is a u-joint? I assume you have removed the shift lever?, stomp starter, clutch linkage, accelerator linkage?, choke cable, battery cables, fuel line?, speedo cable?, heater hose? With all the sheetmetal removed it should be purty simple to take the engine and tranny out. If I've missed something, someone will add to this. | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | I'm familiar with the 4 speeds, and they will not come forward over the transmission cross-member without removing the cab. (Removing the cab is not the easy way... but if you really want to leave a 4 speed on the engine that's the only way to get them out together, or torch the cross-member.)
Are the 3 speeds small enough to slip over the transmission cross-member? If so the radiator and support may need to come out first to make room? Dropping the transmission still seems like the easy way to start.
Grigg | | | | | Joined: Oct 2009 Posts: 12 New Guy | | New Guy Joined: Oct 2009 Posts: 12 | Thanks Yakimabowtie,it was the clutch linkage!!! got it now.lol
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | I think that removing the engine with the three speed connected is not a problem but the 4-speed does not come over the clutch-housing cross member (the rear motor mount cross-member).
There is no transmission cross-member (nor rear mount on the manual transmissions) in 1954.
I would not recommend taking the cab off to get the engine and transmission off UNLESS you are doing a frame-off restoration. In that case, I have even lifted a 54 engine and hydra-matic transmission together off the chassis.
I usually either remove the transmissions first and then the engine; or, I unbolt the transmissions, leave them in place, and remove the engines.
Tim
| | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | I've only once removed a motor from a '54 Chevy and it was a 3-speed. I had already removed the cab so it was pretty easy...
Can you remove the motor and Hydra-Matic as a unit on automatic trucks? Since the crossmember center can be unbolted that would not be an obstacle.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | You do not have to take off the hydra-matic transmission cross member if you are simply lifting the transmission off the chassis (frame-off restoration with the cab removed).
Tim | | | | | Joined: Feb 2000 Posts: 769 Shop Shark | | Shop Shark Joined: Feb 2000 Posts: 769 | You can remove the engine and hydro as a unit with the cab on. I don't remember if I dropped the crossmember to remove the engine. Either way, the crossmember only has 3 bolts on each side. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | You are correct, Lonnie.
The engine rear motor-mount cross-member is bolted on in a 1/2 ton Hydra-Matic equipped truck. Take that cross member off and the engine/transmission could come out the front (with the cab on).
Tim
| | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | The engine rear motor-mount cross-member is bolted on in a 1/2 ton Hydra-Matic equipped truck. Its bolted on in 3/4- and 1-ton trucks also. I don't know about the bigger trucks.
