3 members (JW51, tesa, Ponchogl),
49
0
Mod | | | Forums66 Topics128,076 Posts1,055,925 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2005 Posts: 408 Shop Shark | | Shop Shark Joined: Oct 2005 Posts: 408 | i am going to get headers for my 52 1/2 ton chevy. i have a 57 235 ready to go in it. just a frame right now. i have never used headers and will trust the advice here in the forums. i buy alot of my parts from classic truck parts. do headers really omprove performance or is it more for sound. Thanks Paul | | | | | Joined: Dec 2006 Posts: 1,464 Shop Shark | | Shop Shark Joined: Dec 2006 Posts: 1,464 | I'm gonna say it's for "that sound" although I believe you'll get a slight increase in performance as well. | | | | | Joined: Dec 2008 Posts: 1,922 'Bolter | | 'Bolter Joined: Dec 2008 Posts: 1,922 | Does far more on a motor with a cam change, but it's an improvement in any case. | | | | | Joined: Aug 2007 Posts: 1,859 Grumpy old guy playing with trucks, cars, and boats | | Grumpy old guy playing with trucks, cars, and boats Joined: Aug 2007 Posts: 1,859 | any time you allow the engine to breath easier, you will notice an improvement in performance (whether it is increased fuel economy, more torque, etc.)
However with the new found breathing, cam change, intake changes, etc will fully utilize the new found exhaust breathing.
Stock exhaust manifolds are designed to save the company money, not to be performance oriented.
| | | | | Joined: Sep 2007 Posts: 461 Shop Shark | | Shop Shark Joined: Sep 2007 Posts: 461 | Anytime you let an engine breath better, it will improve performance. I don't think headers alone will give you a noticable seat of the pants feel however. Sound should be better over stock no doubt. Check Jim Carters and Patricks for prices as well.
| | | | | Joined: Oct 2005 Posts: 408 Shop Shark | | Shop Shark Joined: Oct 2005 Posts: 408 | thanks i am also going with the fenton dual carb intake will that increase performance? Thanks Paul | | | | | Joined: Dec 2003 Posts: 2,733 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 2,733 | Absolutely the carb/intake and exhaust header together will help performance. Just don't over carburate.
Check out my setup in the photo link below. | | | | | Joined: Oct 2005 Posts: 408 Shop Shark | | Shop Shark Joined: Oct 2005 Posts: 408 | Nice i wish i had the money for that set up Thanks Paul | | | | | Joined: Sep 2009 Posts: 45 New Guy | | New Guy Joined: Sep 2009 Posts: 45 | I just finished up putting Fenton headers on my 235, with no changes to the stock intake. If you do that, I'd recommend Patrick's for your parts and info. You'll require the linkage rod kit, also, as the stock linkage from the side of the block will not go straight up through the space provided with the new Fenton's. Also, you must remount the swivel for the linkage further back on the block, where there is already a threaded hole just above the rear freeze plug. The pushrod from the gas pedal also needs to be fabricated, or your old one modified. I made one from 1/4" bar stock I got at Home Depot. It was pretty simple. I also got a set of Patrick's terrific stainless steel dual exhaust pipes and stainless steel muffler-2 in and 2 out. It sounds great. If you decide to get that, be certain to have Patrick check the rear manifold exhaust pipe section. The angle on mine was wrong, and I had to cut the flange off and re-weld it. Not a big deal, and Patrick stands behind his stuff-he told me to send him the bill and he would reimburse me. After all of the work, I definitely feel and increase in performance, no more fumes in the truck, and the sound is terrific. Good luck! | | | | | Joined: Mar 2009 Posts: 15 New Guy | | New Guy Joined: Mar 2009 Posts: 15 | Jivermo - you had to mod the throttle linkage and the gas peddle rod?
I have *not* started mine yet (hoping to tomorrow) but I put Fenton's on from Patricks without a linkage kit - or without modifying the gas peddle rod - and everything seems "ok". The throttle linkage required a little map gas, pliers & a vice but nothing major.
Wondering now if I'm in for a surprise tomorrow when it starts (?). | | |
