| | | Forums66 Topics128,113 Posts1,056,279 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2009 Posts: 7 New Guy | | New Guy Joined: Oct 2009 Posts: 7 | I am in the process of restoring the rims on my 1959 Apache flat bed. It was a special order out of CA for a ranch. Does anyone know what the original rim color is? These are not the 2 piece rims. | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy 59apache36, welcome, if the truck was a single solid colour, then the wheels would have been black. If the truck was a two tone, I would have to know the colours to tell you what the wheel colour would have been, hope that helps. | | | | | Joined: Oct 2009 Posts: 7 New Guy | | New Guy Joined: Oct 2009 Posts: 7 | Thank you for responding. The original colors are dawn blue and bombay ivory. The rims measure 19.5 x 6 and have 8 lugs with 3 oval slots. Couple other questions if you know: Was there any pin striping on these rims? Is the finish glossy or flat? Thanks | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy 59apache36, your wheels would have been dawn blue, and the same finish as the body, no striping is mentioned in my reference material, hope that helps. | | |
