| | | Forums66 Topics128,076 Posts1,055,920 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2009 Posts: 24 New Guy | | New Guy Joined: Oct 2009 Posts: 24 | Can i bolt a sm465 4spd to a 216? I'm thinking that i'll have to get a different bellhousing, but i'm not sure which one i need. I have a rebuilt 216 and i've searched the forums but it seems like most people were asking about putting a V8 into their trucks. My truck is a '40 chevy. I was hoping to use the original mounts as much as possible. | | | | | Joined: Mar 2004 Posts: 874 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 874 | The pilot hole in your bell housing is too small to accept the SM465 front bearing retainer. You will need to turn down the the SM465 bearing retainer and/or bore your pilot hole bigger. I believe it's been done before... | | | | | Joined: Oct 2009 Posts: 24 New Guy | | New Guy Joined: Oct 2009 Posts: 24 | The bellhousing that i have right now is the one for the small toploader 3spd. Do I have to get a 420 bellhousing to make everything work? | | |
