2 members (Materman, jrs48pu), 96 guests, and 1 robot.
Topics128,072
Posts1,055,906
Members48,429
#587064 10/27/2009 6:18 PM
i am going to get headers for my 52 1/2 ton chevy. i have a 57 235 ready to go in it. just a frame right now. i have never used headers and will trust the advice here in the forums. i buy alot of my parts from classic truck parts. do headers really omprove performance or is it more for sound. Thanks Paul
wodniw5 #587068 10/27/2009 6:25 PM
I'm gonna say it's for "that sound" although I believe you'll get a slight increase in performance as well.
waldo53 #587151 10/27/2009 11:55 PM
Does far more on a motor with a cam change, but it's an improvement in any case.
panic #587159 10/28/2009 12:03 AM
any time you allow the engine to breath easier, you will notice an improvement in performance (whether it is increased fuel economy, more torque, etc.)
However with the new found breathing, cam change, intake changes, etc will fully utilize the new found exhaust breathing.
Stock exhaust manifolds are designed to save the company money, not to be performance oriented.
panic #587160 10/28/2009 12:05 AM
Anytime you let an engine breath better, it will improve performance. I don't think headers alone will give you a noticable seat of the pants feel however. Sound should be better over stock no doubt. Check Jim Carters and Patricks for prices as well.
1951 restoration on website
http://www.hanklong.com
Hankdogg #587417 10/28/2009 6:29 PM
thanks i am also going with the fenton dual carb intake will that increase performance?
Thanks Paul
wodniw5 #587440 10/28/2009 8:21 PM
Absolutely the carb/intake and exhaust header together will help performance. Just don't over carburate.
Check out my setup in the photo link below.
1953 Chevy 5-window 3100
More pix on Picturetrail
Dave
Engine & Driveline Moderator
Nice i wish i had the money for that set up
Thanks Paul
wodniw5 #587684 10/29/2009 4:33 PM
I just finished up putting Fenton headers on my 235, with no changes to the stock intake. If you do that, I'd recommend Patrick's for your parts and info. You'll require the linkage rod kit, also, as the stock linkage from the side of the block will not go straight up through the space provided with the new Fenton's. Also, you must remount the swivel for the linkage further back on the block, where there is already a threaded hole just above the rear freeze plug. The pushrod from the gas pedal also needs to be fabricated, or your old one modified. I made one from 1/4" bar stock I got at Home Depot. It was pretty simple. I also got a set of Patrick's terrific stainless steel dual exhaust pipes and stainless steel muffler-2 in and 2 out. It sounds great. If you decide to get that, be certain to have Patrick check the rear manifold exhaust pipe section. The angle on mine was wrong, and I had to cut the flange off and re-weld it. Not a big deal, and Patrick stands behind his stuff-he told me to send him the bill and he would reimburse me. After all of the work, I definitely feel and increase in performance, no more fumes in the truck, and the sound is terrific. Good luck!
Jivermo #589267 11/03/2009 6:02 AM
Jivermo - you had to mod the throttle linkage and the gas peddle rod?
I have *not* started mine yet (hoping to tomorrow) but I put Fenton's on from Patricks without a linkage kit - or without modifying the gas peddle rod - and everything seems "ok". The throttle linkage required a little map gas, pliers & a vice but nothing major.
Wondering now if I'm in for a surprise tomorrow when it starts (?).
1956 Chevy 3600 NAPCO 4x4
1955 Second Series Chevy Short Box
1956 Chevy 3100 Short Box
Story in the Gallery
More pix and info on my web site
