| | | Forums66 Topics128,064 Posts1,055,860 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#58698 04/02/2006 12:50 AM | Joined: Mar 2006 Posts: 29 Apprentice | | Apprentice Joined: Mar 2006 Posts: 29 | My 65 C10 has a 3 on the tree with headers. The part in question is the clutch control arm. I think that is what it's called. It connects to the frame on one side and the block on the other. When you engage and disengage the clutch pedal it swivels at these points. One appendage on the arm hits (or rests on) the headers when clutch pedal is up. When you push the clutch pedal in, the arm moves away from the headers.
Is there a way to prevent the arm from hitting the headers?
Will this cause a problem for the headers later? I considered putting a dent in the header tube, but that would mean about a half inch dent.
Some catalogs state that the 65 C10 with 3 on tree requires modification to the clutch linkage when installing headers. Does anyone know what that modification is? I may need to perform this mod.
Thanks. | | |
