| | | Forums66 Topics128,057 Posts1,055,815 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2006 Posts: 33 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 33 | I would like to know what rear springs most of you use after you do a rear end swap. Do you use the original springs? This question would be directed at 1950-53 1/2 tons.
Mike | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | I used a '55 first series rear end and springs. They bolt right up to the existing shackles.
| | | | | Joined: Dec 2007 Posts: 180 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2007 Posts: 180 | I used the rear spring kit from TCI. it is a direct bolt in and it also centers the axle in the wheel wells. 4 inch drop also | | | | | Joined: Mar 2005 Posts: 576 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 576 | I also used a kit but from Chassis Engineering.also a bolt in and centered up the axle, almost a 5" drop.........dave 1949 Chevrolet 3100 "When this thing hits 88 miles an hour, you're going to see some serious sh%t." -Doc Brown
| | | | | Joined: Sep 2006 Posts: 33 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 33 | I'm not wanting to lower it so aftermarket springs are out. How many used the stock springs and how did you do it? | | | | | Joined: Oct 2009 Posts: 5 New Guy | | New Guy Joined: Oct 2009 Posts: 5 | Mike, My 52 uses the original rear springs, although they are mounted below the axle for lowering. The previous owner did this work and near as I can tell he fabbed his own lower spring pad/shock mount. As far as I know the rear end is a 10 bolt from a Nova[not sure what year]. I imagine you could mount the springs like stock by making your own upper pad/shock mount and using proper sized U bolts. Just make sure you center the wheels in the fenders.
Malcolm1943, if it ain't broke, you aren't pushing it hard enough!
| | | | | Joined: Aug 2007 Posts: 1,859 Grumpy old guy playing with trucks, cars, and boats | | Grumpy old guy playing with trucks, cars, and boats Joined: Aug 2007 Posts: 1,859 | Chrysler spring perches or hit up tractor supply.
| | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | I used a spring set from TCI. I don't intend on pulling and hauling heavy loads in my 3600 and I knew how stiff those original springs were.
~Jim
| | | | | Joined: May 2005 Posts: 487 'Bolter | | 'Bolter Joined: May 2005 Posts: 487 | The locating pin on the spring pack is set up for the pivoting axle mount for the torque tube on the original AD trucks. If you use the mounting kit from CPP, it has an offset hole in the spring perch to center the rear axle on the stock springs. If you rolled your own for spring perches, you have at least two choices. First, you could drill an offset hole in the perch. Second, you could turn the springs around. If you swap ends with the spring it will move the locating pin closer to the center. This requires removing the bushings from the spring eyes and swapping them. A moderate amount of work, but you needed to replace the 50 year old ones anyway.
regards, Leon | | |
