| | | Forums66 Topics128,051 Posts1,055,768 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#58667 04/01/2006 12:15 PM | Joined: Feb 2005 Posts: 469 Shop Shark | | Shop Shark Joined: Feb 2005 Posts: 469 | Does any body know where you can buy rivet on brake liners. I need some for a 15x3 1/2" shoes. This is for off road so DOT specks need to be met. | | |
#58668 04/01/2006 4:40 PM | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy ttodd, any good heavy truck supply shop should be able to help you. What was the original application for that size of lining, front brakes off of a three ton from the sixties or seventies? Hope this helps. | | |
