3 members (klhansen, dt235sd, 1 invisible),
67
0
Mod | | | Forums66 Topics128,049 Posts1,055,679 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2009 Posts: 8 New Guy | | New Guy Joined: May 2009 Posts: 8 | I'm still new to all this!
I have a newly acquired 1988 s10 t5(3.76 1st. .72od). I found a 1991 gmc t5 (4.03 1st .86od). My question is, can the overdrive gears in the 3.76 be swapped with the overdrive gears in the 4.03?
gmbs | | | | | Joined: Aug 2007 Posts: 1,859 Grumpy old guy playing with trucks, cars, and boats | | Grumpy old guy playing with trucks, cars, and boats Joined: Aug 2007 Posts: 1,859 | yes, you can play mr potato head with the T-5, however you wont gain much with the .72 over the .86.
just watch the oiling funnel in the rear housing. Make sure the funnels stays with the appropriate housing.
| | | | | Joined: May 2009 Posts: 8 New Guy | | New Guy Joined: May 2009 Posts: 8 | Thanks Scott! That's all I need to know! I have a 4.57 full floater rear end so, I need every little bit of mechanical advantage I can get!
GMBs | | | | | Joined: Mar 2006 Posts: 76 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2006 Posts: 76 | GMBs, It sure seems like the T-5 that you have would work great, as is. In fact, I would think that with the 4.57 rear gear the 3.76 first gear would be preferable to the 4.03 first gear. Our 64 C-20 has the 4.57 gear in it and our 5 speed has a 2.95 first gear and the only time I wish I had more "gear" is when I'm pulling a trailer. I guess it all depends on how you are going to use the truck. Good luck! Ron | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | I think it would be best to have the 3.76 & 0.72. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
