7 members (FishinToms53, Hotrod Lincoln, Rich'sToys, Stovebolt48, 50shep, Millenimech, mason86), 75 guests, and 5 robots.
Topics128,030
Posts1,055,428
Members48,422
#585682 10/23/2009 1:17 AM
I'm still new to all this!
I have a newly acquired 1988 s10 t5(3.76 1st. .72od). I found a 1991 gmc t5 (4.03 1st .86od). My question is, can the overdrive gears in the 3.76 be swapped with the overdrive gears in the 4.03?
gmbs
gmbs #585707 10/23/2009 2:29 AM
yes, you can play mr potato head with the T-5, however you wont gain much with the .72 over the .86.
just watch the oiling funnel in the rear housing. Make sure the funnels stays with the appropriate housing.
Thanks Scott! That's all I need to know! I have a 4.57 full floater rear end so, I need every little bit of mechanical advantage I can get!
GMBs
gmbs #585863 10/23/2009 5:02 PM
GMBs,
It sure seems like the T-5 that you have would work great, as is. In fact, I would think that with the 4.57 rear gear the 3.76 first gear would be preferable to the 4.03 first gear. Our 64 C-20 has the 4.57 gear in it and our 5 speed has a 2.95 first gear and the only time I wish I had more "gear" is when I'm pulling a trailer. I guess it all depends on how you are going to use the truck.
Good luck!
Ron
Arpee #585910 10/23/2009 8:49 PM
Riding in the Passing Lane
I think it would be best to have the 3.76 & 0.72.
1972 Chevy c10 Cheyenne Super
