6 members (JW51, KEVINSKI, Joe H, WingWright, 3800GUY, Gdads51), 121 guests, and 1 robot.
Topics128,110
Posts1,056,255
Members48,437
Hi,
Ok, I have the shop manual with wiring diagram, a voltage reducer to take 12v down to 6, etc. Now I see that there is a bent ribbon of metal connecting the two poles on the gas gauge (see Photo)
http://picasaweb.google.com/lh/photo/uDRN11f1NhAr2dnuRUechw?feat=directlink
It looks original but I am having a hard time understanding how this circuit will not bypass the gauge. Any thoughts on this situation? Should I just hook up the wires and see what happens?
thanks,
-doug
Doug,
That bent ribbon isn't metal, I believe it's paper, and it's suppose to be a insulator to keep wrenches and other things from shorting the two terminals together.
Your voltage reducer goes in series (inline) with the wire from key to gauge. Does this make sense!
Stuart
Totally - Thank you Stewart. I'll try and get the voltage reducer in this weekend and see if the gauge works. Once I get all the gauges working I have to restore the whole cluster (paint and lettering, etc.) but at least I'll know that it functions.
cheers, Doug
