4 members (Hotrod Lincoln, 52Carl, TUTS 59, papas52), 119 guests, and 2 robots.
Topics128,162
Posts1,056,932
Members48,458
#585691 10/23/2009 2:10 AM
U
U Offline
Hello,
Can anyone tell me if the cross support bars on the 57 Chevy hood should be straight or bent like mine ?
I bent them straight and now they do not match up with the holes.
Thank you!
Jon
1957 Chevy 1/2-Ton Truck
More pix
The coldest winter I ever saw was a summer I spent in San Francisco M. Twain
If at first you don't succeed...skydiving is not for you!
If you don't like my carbon foot print, stick it up your Prius!!
3B Offline
Hy Unklrod, if my memory is correct they are a little bent, hope that helps.
U
U Offline
3B,
Is there a reason why they would have bent them? Clear the Air cleaner? Maybe?
Thanks!
Jon
More pix
Yes, it should be bent.
Bill Burmeister
those stiffners are bent to align/square/flatten the hood and stress the crown so it doesn't flap in the wind so much - the factory tweaked each to suit the stamping, you'll find every TF has'em bent and none are quite the same ..... big mistake to straighten them out frown
U
U Offline
Great,
Now I am upset!
I did not ask the shop to do that!
Bill,
Jon
More pix
U
U Offline
Another question yet I already know the answer,
Should the stiffners be out of the truck while they are fitting the hood to the front fenders and cab? Because the shop has been cutting the driverside of the hood sorta near where the hood closes by the head light to make it fit without the stiffners.
Thank you,
Jon
More pix
not sure it'd make a big difference for a 'static fit', but also don't see why the hood should need any cutting to make it fit - if the hood is too tight just at that front bit maybe a shim or 2 is needed between the rad support and the fender ohwell
3B Offline
Hy Unklrod, as red58 said the rods were there to "stress" the hood, if that is the case then they should be in place for any fitting. And I don't think you should have to be cutting the hood to make it fit after all these years.
dang, you guys got me curious..
i will have to pop the hood on my 57 this weekend to see how mine are... i swear they are straight.
leonard
1957 Chevy 3100 1/2-Ton
Photobucket pictures
That would explaing why mine are different from the posted pic. Mine is bent similar, only the bend is on the RR side of where the bars cross.
Bill Burmeister
Some were straight, some were bent. These are crucial for the fitment of the hood. Time and error will be needed to put these back close to what they were. Put'em back in and maybe find another unit of like year, 5,6,7,8, maybe a 9, and tweak yours in a similar manner for starters. Hope this helps.
dg
Yes, I like the line "so the hood does not flap so much in the wind"! I cannot say that my hood flaps, but at speed, or with a headwind, the hood bends down, it kind of make a wave in the middle of hood! Yes, I do have the stiffeners, but I guess these trucks are really not aerodynamic!!!
'57 Chevy Suburban; '70 Chevy Impala.
the TF hoods are all a bit flexy at speed regardless, but without that X bracing it'd be scarey - I think that's why they added the 'wind splits' on the 57 and reshaped the 58/9, but that didn't help much
I moved this to Paint and Body for future reference. Anyone re-assembling their front sheet metal needs to know this.
wow.
sure enough, mine is slightly bent on the drivers side.
http://s251.photobucket.com/albums/...00/?action=view&current=DSC02590.jpg
funny how we dont really notice small things like this on our trucks.
leonard
Mine are bent on both my '58s.
Mike
1958 Chevy 3200 Fleetside
1958 GMC 100 Wideside
Did you get free advice today? To donate to this site using PayPal is fast and EZ. Click here: http://www.stovebolt.com/office/thanks.html
U
U Offline
3B,
Yup, The shop went ahead and straigheten the supports with out asking. Then they went ahead and shaved the driver side edge of the hood because it was not fitting. I got some long winded excuse that the gaps were not matching up on the doors fenders and hood. I have reached the end of my patience with this shop. I am bringing the truck home and I am going to find another shop to finish.
More pix
