1 members (Hotrod Lincoln), 72 guests, and 0 robots.
Topics128,049
Posts1,055,680
#58559 03/30/2006 4:39 PM
Junior Member
Junior Member
I have a 54' chevy 3100 235 1bbl rochester. I've been having fuel flow issues... not enough when loaded even with new fuel pump.
I found a 6v master electric fuel pump. Anyone try an electric? How well does it seem to work?
#58560 03/30/2006 4:50 PM
trash in tank or plugged sock?
#58561 03/30/2006 4:51 PM
Junior Member
Junior Member
washed tank, new fuel pump, new pickup, new fuel lines, rebuilt carb
#58562 03/30/2006 5:22 PM
did you rebuild the carb or buy one already rebuilt? if you purchase it, I would check the float level in the carb
There should be plenty of pressure and volume from a stock pump for a 235.
#58563 03/30/2006 11:05 PM
Riding in the Passing Lane
Electric pumps work good but is kind of a chicken way out. You should be able to fix it. The electric pump can be dangerous. In an accident or fire or flooding carb. it will keep on pumping. An oil pressure switch can help.
1972 Chevy c10 Cheyenne Super
#58564 03/31/2006 2:26 AM
Junior Member
Junior Member
My truck would start instantly the next day but would grind forever if parked for a week. There seemed to be a weird fuel leakdown, fuel pressure issue that I did not begin to understand.
I installed a inline electric pump controlled by a switch.
The electric pump is used only for pre start and is turned off before the starter is pressed.
The engine now fires on the first turn every time.
Mike
