| | | Forums66 Topics128,154 Posts1,056,853 Members48,456 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2009 Posts: 75 'Bolter | | 'Bolter Joined: Mar 2009 Posts: 75 | Hello,
I'm attempting to assess and repair the wiring in my '40 1/2 ton. There is a relatively new wiring harness making many of the critical connections but also lots of new wires that don't go anywhere and some original wires that are still hanging around.
Does anyone have a wiring harness diagram from a newer harness? (don't know the brand)
thanks - Doug (truckin39) | | | | | Joined: Oct 2009 Posts: 42 New Guy | | New Guy Joined: Oct 2009 Posts: 42 | i had this too in my 63, most of the excess wire was for a radio...you'll have to get a wiring diagram i'm sure, i got mine from ebay, but lots of companies sell them for less than 10 dollars. have u checked into that yet? let me know.... | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | diagrams aren't for harnesses, they're for vehicles - assuming you're talkin a fairly stock '40, you need to make the right connections with whatever wire you have - the 41 diagram will do itBill | | | | | Joined: Mar 2009 Posts: 75 'Bolter | | 'Bolter Joined: Mar 2009 Posts: 75 | Thanks Bill and 63lwbc10,
Bill your 41 diagram is quite useful and quite a bit more complex than my '40 diagram (lots more lights). They also reoriented the diagram in 41 that maps to the car - Headlights on one end, tail lights on the other - which is much better than the abstract layout of the '40. The added complexity is also better due to the fact that my '40 now has tail lights and blinkers too!
Cheers,
Doug | | | | | Joined: Jun 2006 Posts: 687 Shop Shark | | Shop Shark Joined: Jun 2006 Posts: 687 | Those aftermarket wiring kits are great. I got one for a 1954 corvett from Letrics and it came with a laminated 2 ft. by 3 ft. schematic I now have mounted on my garage wall. Talk about fun to install @#$%^&. Because the Vet is fiberglass everything electric has a seperate ground wire. Hell the antenna (a flat plate located inside the deck lid between layers of fiberglass) has a ground wire.
I didn't do it, no one saw me do it, you can't prove anything! "Bart Simpson" | | |
