Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
2 members (Rich'sToys, Dakota Bob), 144 guests, and 3 robots.
Topics128,283
Posts1,058,505
Members48,490
#585399 10/22/2009 2:13 AM
1957 GMC Rear-end Housing
Ok. The truck that I’m trying to buy has a brace welded to the axel tube over the pumpkin to the other axel tube.
Sorry for the photos you can just see it if you look close.
Is this normal?
Or is this bad?
http://s758.photobucket.com/albums/xx221/jskmetcalf/1957%20GMC/
Make Love your strongest weapon. Compassion your shield and forgiveness your armor.
Does make me wonder if the truck's been overloaded at one point. I've seen similar modifications on axles used in stock cars. The idea is to stiffen the axle housing. Does the truck drive alright? No funny camber wear on the rear tires (which would indicate a bent housing)?
I'm not sure that I would worry too much if everthing checks out.
Bill Burmeister
I would think a stiffner would be under the housing, but you never know what a previous owner had in mind.
