7 members (frogfarmer, Hotrod Lincoln, 52Carl, KEVINSKI, Cletus1950, 1955 1 Series, fonz8261), 118 guests, and 2 robots.
Topics128,177
Posts1,057,060
Members48,460
#585155 10/21/2009 3:31 AM
Apprentice
Apprentice
I found a '51 and the guy says it is a 2.5 ton, what would the total weight be of the truck? Trying to decide wether I can go get it or need someone else to. Thanks
Be American, Buy American
J Man #585217 10/21/2009 11:39 AM
If it's a '51 Chevrolet, it would be a 2 ton. Need a few more specifics. Get the number from the ID plate in the driver door jamb. That number will tell if it's a 1 1/2 ton, 2 ton etc. Weight of a '51 Chevy 2 ton would be between 4500- 5000 lbs., in cab, & chassis form.
Spanky Hardy
More pictures on Photobucket
1950 GMC 250 1-Ton
1 Offline
That's probably right but most time the truck will have some sort of bed and it adds a 1000 or 2000lbs. I think my long box 47' 2-ton weights around 7000 to 8000lbs. I know for sure my uncles truck weighs 5900lbs and it's a 97' chevy 1 ton with a 454 BB. So the old 2-ton has to weigh more than that.
1947farmer
1947 2-Ton Chevy
Story in the Stovebolt Gallery
More pix in Photobucket
1977 3/4-ton
1985 2.5-ton
2- 1947 Allis WC
1- 1949 Allis allcrop
1- 1955 Allis WD-45
1- 1976 Allis 7040
"If it ain't broke you ain't trying"
Apprentice
Apprentice
I was wrong on the year it is a '52. Someone else ended up beating me to it but thanks for the help. I will be goo reference for next time.
Even a 52 Chevy would have been 2 ton at the most.
Was it not until 55 that Chevy had a larger than 2 ton truck??
The problem with hauling larger trucks is that they are to wide a tread to drive onto most bumper pull trailers. I have loaded them on a tilt car hauler I have by removing the outside dual and backing them on. But it is safer to haul them on a trailer with a deck above the tires and a goose neck. Of course my preferred method is on a flatbed behind a semi. Backing them on really doesn't get enough tongue weight to be safe. The actual difference between a 2 or 2 1/2 ton isn't that much. It is the heavier rear axle, 20" tires and and duals that make them weigh more than a pickup. And of course any bed will be heavy.
1956 was the first year Chevrolet had a larger than 2 ton truck offered.
Spanky Hardy
1950 GMC 250 1-Ton
