2 members (Tronman, 50wudy), 168 guests, and 2 robots.
Topics128,189
Posts1,057,337
Members48,469
#585168 10/21/2009 4:08 AM
Any idea's on what year rear end with six bolt wheel pattern that is 59 inches wide to replace stock 1936 rear end with open drive shaft type. Arround 340 to 350 ratio more or less. thanks for any help in advance.
check your local junk yard for ford explorers with 8.8" rear diff. yuo should be able to find one that is very close to the size you need.
Malcolm1943, if it ain't broke, you aren't pushing it hard enough!
check your local junk yard for ford explorers with 8.8" rear diff. yuo should be able to find one that is very close to the size you need.The only problem is the six lug, your local machine shop should be able to redrill the hubs.
You can order an IMCA modified full floating 9 inch rear with disc brakes, 6 lug, and any width you can imagine. check out 9inchfloater.com. I used one of these rear ends for my 1940 gmc.
We used US market Isuzu Rodeo rear end from a '96 vehicle for my brother's '36 truck. It's a Dana 44 six lug which has the correct 5.5" PCD.
It's 58" mounting face to mounting face wide and has discs with E brake shoes inside. The one we bought had a posi in it too.
Stuart.
Thanks to all of you. The information will be very helpful! I am trying to keep the "babe" as close to original looking as possib le while making her safe and reliable for daily use. Putting a 292 (six cylinder), four speed in to allow for freeway driving, which we need out here in Arizona, as nothing is close when you need somthing.
Update, a rear end out of a 1990 nisson pathfinder, two wheel drive is exactly 59 inches wide, the same width as the original! with the correct wheel bolt pattern.
Keep in mind, everything on that Nissan rear (actually an Aisin) will be metric. So the lug stud threads will be different. Should be 12mm x 1.5.
Bill Burmeister
LONGBOX55 #589017 11/02/2009 3:49 PM
Correction, the rear end is out of a 95 pathfinder. Just an additional note, it is a well built, heavy rear end, with larger brakes than most "rice burners" With all of the unneeded brackets removed, fits like a glove. Rear shock mounts are perfect for use in the truck. This allows for the use of 8 inch wide rear wheels, with a 4 inch offset. I would like to take a moment again and thank those of you that offered advice and assistanc! You are what makes this forum so great.
