2 members (Millenimech, klhansen), 161 guests, and 1 robot.
Topics128,115
Posts1,056,289
Members48,439
I was wondering if there is anything magical to adjusting the nut and bolt that attaches the parking brake fulcrum lever to the backing plate on the rear drums. I am having trouble getting the tops of the shoes to hug the anchor pin and it is causing the shoes to drag when I install the drums and I have nowhere to go from point with respect to adjusting the brakes. Please help.
Whad you do?!?
Shane
1953 Chevrolet 3600
Just wanted to get this back up to the top...does anyone have any idea about making this adjustment or if I am even right about it?
Whad you do?!?
Shane
1953 Chevrolet 3600
I don't believe there is any adjustment on the parking brake other than the nut at the end of the cable. None inside the drum. If the shoes don't retract you need to look elsewhere for that problem. Usually, just a couple of stomps on the brake pedal after the drums are on will center and align the shoes. That's assuming the adjuster, springs and retainers are installed correctly.
Riding in the Passing Lane
Some models have an eccentric bolt holding the lever to the shoe. Loosen the nut & turn the bolt to see if it changes the position.
1972 Chevy c10 Cheyenne Super
