0 members (),
186
Mod | | | Forums66 Topics128,143 Posts1,056,494 Members48,442 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2007 Posts: 28 Apprentice | | Apprentice Joined: Mar 2007 Posts: 28 | I just mounted the box on my 48 3600 and I have an inch+ gap between the front of the rear fenders and the running boards/splash aprons. I believe the cab and frame are 48 vintage but the box is possibly a few years newer. I got the truck with a home made flatbed mounted. The long running boards were still on it but the splash aprons are a different color from the cab so they and the running boards might be a different year also. Were there difference between the years that are causing my problem. I can't see any way to get enough movement from anything to get a propper fit. Any suggestions appreciated.
Life is simpler if you plow around the stump.
| | | | | Joined: Jun 2009 Posts: 2,201 Shop Shark | | Shop Shark Joined: Jun 2009 Posts: 2,201 | What is your gap between the cab and bed? Recent discussion on here suggests that it could be anywhere from 1/2" to 2" or even more. I think it should be about 1" at the center of the bed, but I can't prove it. If there is no spare space there you might have to do some refab work somewhere. Loosen up the running boards and see if you can get a little bit there and you might be able to loosen the fender bolts and get a little movement there too. I suggest get everything loose and see if you can tweak a little here and a little there. | | | | | Joined: Mar 2007 Posts: 28 Apprentice | | Apprentice Joined: Mar 2007 Posts: 28 | The cab to bed at the closest point is about an inch. If I slid the box forward to touch the cab the fender to running board fit would be about right. I think I could adjust the fenders and boards each a little but not enough. Maybe elongate the frame holes and gain a little on the box.
The box and fenders (one fender the other is a replacement) came from a different truck. They fit ok when on it. The running boards may not be original to the truck. I don't know as it had a flatbed on it when I got it.
If all of the AD's used the same boards beds and fenders I will try to get these to fit the best I can. If not maybe I need to find different boards or fenders.
Thanks Richard
| | | | | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | There was a set of short running boards intended for use with flatbeds that won't fit on a truck with fenders. Can you measure your set and post the result?
