1 members (VicZ), 231 guests, and 2 robots.
Topics128,087
Posts1,055,976
Members48,430
#584610 10/19/2009 7:19 AM
Been thinking about swapping my 4 speed for a five/OD. My question,Can I use one from,say a '97 3500? It's going into my 6100 w/two speed & 235.
1953 Chevy Two-Ton
More pix on Photobucket
Be careful calling yourself a expert,because an "EX" is a hasbeen and a"SPERT" is a drip under pressure.
PapaJ #584618 10/19/2009 10:42 AM
Yes, but not very easily. It would be eazier to use the 5 speed out of a 94-97 dodge 3/4 ton or 1 ton. Both the gm and dodge used a transmission called the New Venture 4500 or NV4500. The New Venture plant was formed with the merging of the Muncie transmission plant and the New Process transmission plant. It was formed as a "joint venture" between GM and Dodge.
Why the dodge version?
The dodge NV4500 is easier to swap into older gm vehicles because it can more easily be adapted to run a mechanical speedometer. The input shaft of the dodge version is 1 inch longer than the input shaft of the gm version. The extra length allows you to use an adapter plate that is 1 inch thick to go from the NV4500 to the gm bellhousing. The NV4500 that was used in the gm trucks does not have the typical gm bellhousing patern, so it will not bolt up to the older gm bellhousings.
The 94-97 dodge 2wd nv4500 transmission is the one needed to run the mechanical speedo... oops, you mentioned a 2 speed rearend... I am not sure where the speedo gear lives on that setup.
There is plenty of info about this transmission on the internet. Do a search. I have swapped this transmission into a 59 gmc 1/2 ton. They are rated for moving about 16,000 lbs
Speedo is still in the tranny.rearend is shifted separately.
1953 Chevy Two-Ton
PapaJ #584738 10/19/2009 7:08 PM
Ok wasn't sure about that. I guess there is some type of speedo gearbox which also shifts when the rear end is shifted.
Advanced Adapter makes an adapter plate that will work with a little bit of machining. The macining involved has to do with the "indexing" or centering of the plate to the bellhousing. The bellhousing for your chevy has a center hole that is 4.686 inches in diameter. The adapter plate is made for a 67 and later bellhousing which has a center hole of 5.125 inches. To bolt the adapter plate to the bellhousing, either the bellhousing needs to be bored out to 5.125 inches, or the adapter plate needs to have the indexing lip turned down to 4.686 inches.
The NV4500 is a stout transmission weighing in at 200 lbs. you will have to fabricate a new rear crossmember to support the tail section of the transmission.
When installed the shift tower will be moved back about 6 1/2 inches from the location of the stock sm420. The shifter will be closer to the seat.
Dodge used a heavy duty and standard duty version of the transmission. The standard duty uses a 10 spline 1 1/8 pilot shaft. The heavy duty uses a 10 spline 1 1/4 pilot shaft. I know the 1/2 tons through 1 ton gm vintage trucks used a 1 1/8 10 spline clutch, however I am not sure of what the 2 ton trucks used. In my application I was able to use most of the stock clutch assembly. I had to order a speacial pilot bearing. I was able to use the stock clutch, pressure plate and throwout bearing.
The snout of the bearing dodge standard duty bearing retainer had to be turned down on a lathe to fit the stock throwout bearing. I believe there is an aftermarket throwout bearing which will work as is. I wanted to use as many of the stock parts as possible to make finding the necessary parts easier.
OK enough about the NV4500, have you searched for a "Clark" 5 speed with overdrive? This transmission was an option for your truck and will bolt directly in. The OD ratio is not as high as the NV4500.
Thanks for the info I'll have to do a search on the "clark".
1953 Chevy Two-Ton
