| | | Forums66 Topics128,077 Posts1,056,019 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2008 Posts: 17 New Guy | | New Guy Joined: Nov 2008 Posts: 17 | The wiper actuator arms, the flat pieces of metal that connect to the wiper motor on one end and the wiper blades on the other, came off on my 1949 Chevy 4400 (1.5 ton). They were held on to the wiper motor drive lever via a clip. I have the clips... they wound up on the floorboard. The clips seem to have had a spring attached and et cetera. I don't want to pull everything out of the dash and pull the wiper motor. I can reach the back of the wiper motor and can put the actuator arms back on the wiper motor drive lever, but I can't see it (but I know what is there by feel).
Does anyone know how the original clips were configured? Any advice for a work-around when the original clips fail?
Harrell (Lee)
| | | | | Joined: Jan 2008 Posts: 4,961 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,961 | The two clips kind of resemble the tabs on beer cans. They had a hole in them and were held in place by a small spring. I'm not sure if a spring that small is available at parts houses. A spring out of a retractable pen might work. If you loosen the wiper motor a little, you can twist it around a little and see what you are doing. The arms go on about a 3/16 post with a snap ring grove towards the end. This is where the tabs go and the spring keeps them in place by pulling against each other. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | | | |
