6 members (Gray_Ghost, VEW, FAST55, 50Chevy3100, J Lucas, 1 invisible), 70 guests, and 0 robots.
Topics128,075
Posts1,055,918
Members48,429
#58417 03/28/2006 3:59 PM
I tried removing the crankshaft timing gear with a puller and PB Blaster but it wont budge. Any suggestions?
#58418 03/28/2006 5:15 PM
machine shop,,,has to be pressed..
#58419 03/28/2006 6:19 PM
Theres no way to pull it off with a puller with the crank in the block?
#58420 03/28/2006 8:07 PM
Apprentice
Apprentice
Bob,
I pulled the gear from the fron of my 1942 216 motor so I could get the camshaft out. After breaking my old gear puller, I gently heated the gear - trying to keep the heat to the gear and not the shaft.
Some taps with a punch to allow the liberally applied penatrating oil to soak in eventually yielded a seperate gear and shaft. Also try applying and releasing teh pressure from the gear puller a few times - this seemed very effective.
The gear on the end of the cam does need to be pressed off. Good luck.
Stewart
#58421 03/28/2006 11:40 PM
You'll have to press it off.Those cam gears are relly tuff . I am amazed how tuff they are !!!!
1951 3100 Chevrolet
#58422 03/29/2006 2:53 AM
I just removed the crank and cam gears in my shop using gear pullers, penetrating oil, propane torch, impact wrench, and a brass drift. They did not come willingly, but they did come off w/o damage. I had the crank gear under a great amount of tension from the gear puller, heated the gear all the way around with the torch, applied penetraiting oil to the seams and then I struck the gear with the brass drift and the gear just popped loose. I removed the cam gear by placing cam gear on top of the opened jaws of my vice with the cam pointing towards the floor and heated the gear w/ the torch again. Then I used a large brass drift and a hammer to drive the cam out of the cam gear. Good luck and wear a face shield and gloves in case the puller gives way before the gear! eek
Jim
1954 GMC 1/2-ton Longbed
1971 Pontiac LeMans Sport
#58423 03/30/2006 3:12 PM
When I was telling my machinist how proud I was after pulling my crankshaft timing gear, he told me that I had done it the hard way. He said the way to do it is to give it some sharp raps with a chisel, between the teeth right over the keyway. Apparently those gears are so hard that they can be cracked quite easily. Apparently that location causes maximum stress on the gear.
1951 1 Ton Completed
#58424 03/30/2006 8:01 PM
6 heaven
6 heaven
drill a hole through the gear. then use a chisel to split it on top of the drilled hole between the teeth.
#58425 04/03/2006 5:34 PM
I avtually got my drill and drilled out the backing plate hole just large enough to slide it over the gear! Wont be having that problem again!
#58426 04/03/2006 8:42 PM
I chiseled mine off, since I was replacing it anyhow I didn't care if it came of in one piece, just that I didn't damage the cam/crank.
Fact is that you don't need to remove the cam gear to get the cam out, but to get the backing plate away from the crank you do need to get that one off, unless you just want to have the machine shop do it for you while they have the crank.
#58427 04/04/2006 2:44 AM
Wrenchbender,how tuff is a cam gear ? HA,HA !! I'll let you tell.
1951 3100 Chevrolet
