2 members (J Lucas, pauld),
123
Mod | | | Forums66 Topics128,183 Posts1,057,263 Members48,467 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2006 Posts: 197 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2006 Posts: 197 | Been here before on this topic, have gone back and forth on it and guess I am back to the idea again.
My question is, since the springs on the 1 ton are 2in and the 1/2 is 1 3/4in the ubolt holes in the axle are different spacing. Is there any issue with opening up the holes in the 1/2T axle so that the 1T U bolts fit? My other thought was using the 1/2T and just grinding down the springs to narrow them, but then realized the thickness of the U Bolts are different.
Thoughts? OldSub I was reading a lot of your previous suggestions and it pointed me back in this direction. I am picking up another 1/2Ton front axle this weekend. | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | Is there any issue with opening up the holes in the 1/2T axle so that the 1T U bolts fit? My other thought was using the 1/2T and just grinding down the springs to narrow them, but then realized the thickness of the U Bolts are different. Thoughts? Enlarging holes sounds OK. Grinding springs to fit the U-bolts is asking for broken leaves later on.. Grigg | | | | | Joined: Mar 2004 Posts: 874 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 874 | I just installed a 3/4 ton front axle on my one ton. They are actually identical axles except for the u-bolt hole spacing. (3/4 ton has the same width spring as 1/2 ton) I elongated the holes with a die grinder to fit the one ton u- bolts. Took about a half hour and worked out great. | | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | You might also consider using the 1/2-ton springs.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | Joined: Dec 2006 Posts: 197 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2006 Posts: 197 | Ghostrider how did you make out with connecting the steering up? I cannot remember off the top of my head what the difference was between the 3/4 and 1/2ton Axle other than possibly bigger Brakes? | | | | | Joined: Dec 2006 Posts: 197 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2006 Posts: 197 | If for some unknown reason, like I am cheap right now, the brake lines compatible anybody know? | | | | | Joined: Dec 2006 Posts: 197 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2006 Posts: 197 | The 1/2 ton springs are shorter aren't they? | | | | | Joined: Jan 2007 Posts: 42 Apprentice | | Apprentice Joined: Jan 2007 Posts: 42 | I have another goofy question.... are the 3/4 axles different than the 1/2 ton? Will the hubs interchange?
The kingpins need to be redone on my 1/2 ton axle. Thinking about rebuild an axle/steering setup on an axle outside of the truck and then swapping it in.
The truck is my daily, so downtime is not practical. | | | | | Joined: Mar 2004 Posts: 874 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 874 | Ghostrider how did you make out with connecting the steering up? I cannot remember off the top of my head what the difference was between the 3/4 and 1/2ton Axle other than possibly bigger Brakes? '47-'52 1/2, 3/4 and 1 ton axles should all use the same drag link. To install your 1/2 ton axle in the 1 ton, all you should have to do is the same procedure I described earlier for the swap I did. | | | | | Joined: Mar 2004 Posts: 874 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 874 | I have another goofy question.... are the 3/4 axles different than the 1/2 ton? Will the hubs interchange? Yes, they are different. The hubs will not interchange. | | | | | Joined: Dec 2006 Posts: 197 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2006 Posts: 197 | Great... Over the weekend I picked up a front end from a 1/2 ton. The guy I got it from used to have about 5 he said until Old Navy bought them up. He kept this one truck that had a strange telephone box setup on it. Never saw anything like it before. That was really neat.
Hopefully in the next week or so I can start working on getting the new one in and the old one out. | | | | | Joined: Dec 2006 Posts: 197 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2006 Posts: 197 | New question, I was looking at wheels for the truck and noticed that the list said load was 1500lbs. Should I be concerned about the load numbers or not since I will never use the 1 ton to carry anything other than me? | | |
