0 members (),
119
Mod | | | Forums66 Topics128,283 Posts1,058,505 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#58361 03/27/2006 4:36 AM | Joined: Mar 2005 Posts: 75 Member | | Member Joined: Mar 2005 Posts: 75 | Were can you get a good head gasket for the 250/ 292 engine that could hold up to 12 to 1 with out leaking. what is the best brand? are could us the whole gasket set. what the best brand to us if you are trying to race these motors.
super250six | | |
#58362 03/27/2006 4:50 AM | Joined: Mar 2005 Posts: 1,636 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 1,636 | Fel-pro makes performance gaskets.
Also might try Mr. Gasket.
I'm sure there are other out ther that mqy even be better thqn that. | | |
#58363 03/27/2006 5:04 AM | Joined: Mar 2004 Posts: 96 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2004 Posts: 96 | Check with Clifford Performance. www.cliffordperformance.net They deal a lot in performance six cylinder parts...if they don't have, they will be able to link you to someone that does and you might learn something interesting about your motor in the process.
Whad you do?!?
Shane 1953 Chevrolet 3600
#58364 03/27/2006 8:28 AM | Joined: Apr 2005 Posts: 2,832 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,832 | Sounds like your putting together a pretty wicked six banger. Why not get it 0-ringed and put an end to any leaking problem? It's a fairly cheap job to have done and is used on all blown engines with high boost.
Evan
