2 members (frogfarmer, Otto Skorzeny), 102 guests, and 1 robot.
Topics128,154
Posts1,056,855
Members48,456
#58352 03/26/2006 10:26 PM
Posted some pics under the miscellaneous category at:
http://community.webshots.com/user/geezer
Have the never ending oil line questions which are important now as I'm closing up the engine. Would appreciate a look at the pics and any comments or advice! Thanks!
Deleted a period after geezer. Think that was screwing it up.
Country Roads, West (By God) Virginia
Quote
We're sorry...
...due to a high volume of page requests, this Webshots page is not available right now.
If you are looking for a photo, it is possible that the photo has moved or no longer exists.
I would guess you have too much help! wink
Fred
52 3600
69 C-10
Got the same thing Fred
Wonder whats up with that?
regards
Edited my opening post. Link is working now. Thanks!
The small hole is a thick washer that should knock out and fit right up to the new U joint half.
I dont like the new method of retaining the spider , with the bent metal under the bolts , I much prefer the old cast item , much less "give" in it. Check the bolt strength , I have had a couple fail with mild steel bolts , really only lasted months. Need really good grade bolts.
The rocker springs and washers are there to stop the rocker moving sideways on the shaft .
Don't know about the oil line .
What are the torque values for the u-joint bolts? Thanks for the help - Bug.
1951 Chevrolet 3100 AD Pickup
