| | | Forums66 Topics128,094 Posts1,056,487 Members48,444 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#58352 03/26/2006 10:26 PM | Joined: Nov 2000 Posts: 582 Shop Shark | | Shop Shark Joined: Nov 2000 Posts: 582 | Posted some pics under the miscellaneous category at: http://community.webshots.com/user/geezer Have the never ending oil line questions which are important now as I'm closing up the engine. Would appreciate a look at the pics and any comments or advice! Thanks! Deleted a period after geezer. Think that was screwing it up. | | |
#58353 03/27/2006 7:22 PM | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | We're sorry... ...due to a high volume of page requests, this Webshots page is not available right now.
If you are looking for a photo, it is possible that the photo has moved or no longer exists. I would guess you have too much help!
Fred 52 3600 69 C-10
#58354 03/27/2006 8:47 PM | Joined: Apr 2003 Posts: 608 Shop Shark | | Shop Shark Joined: Apr 2003 Posts: 608 | Got the same thing Fred Wonder whats up with that? regards | | |
#58355 03/27/2006 9:11 PM | Joined: Nov 2000 Posts: 582 Shop Shark | | Shop Shark Joined: Nov 2000 Posts: 582 | Edited my opening post. Link is working now. Thanks! | | |
#58356 03/28/2006 9:07 AM | Joined: Feb 2001 Posts: 1,096 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 1,096 | The small hole is a thick washer that should knock out and fit right up to the new U joint half.
I dont like the new method of retaining the spider , with the bent metal under the bolts , I much prefer the old cast item , much less "give" in it. Check the bolt strength , I have had a couple fail with mild steel bolts , really only lasted months. Need really good grade bolts.
The rocker springs and washers are there to stop the rocker moving sideways on the shaft . Don't know about the oil line . | | |
#58357 03/28/2006 3:55 PM | Joined: Jun 2000 Posts: 50 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2000 Posts: 50 | What are the torque values for the u-joint bolts? Thanks for the help - Bug.
1951 Chevrolet 3100 AD Pickup
