3 members (Samantha, Otto Skorzeny, tesa), 337 guests, and 4 robots.
Topics128,162
Posts1,057,057
Members48,463
Been here before on this topic, have gone back and forth on it and guess I am back to the idea again.
My question is, since the springs on the 1 ton are 2in and the 1/2 is 1 3/4in the ubolt holes in the axle are different spacing. Is there any issue with opening up the holes in the 1/2T axle so that the 1T U bolts fit? My other thought was using the 1/2T and just grinding down the springs to narrow them, but then realized the thickness of the U Bolts are different.
Thoughts? OldSub I was reading a lot of your previous suggestions and it pointed me back in this direction. I am picking up another 1/2Ton front axle this weekend.
Thoughts?
Enlarging holes sounds OK.
Grinding springs to fit the U-bolts is asking for broken leaves later on..
Grigg
•1952 Chevrolet 3800 pickup
---All pictures---
I just installed a 3/4 ton front axle on my one ton. They are actually identical axles except for the u-bolt hole spacing.
(3/4 ton has the same width spring as 1/2 ton)
I elongated the holes with a die grinder to fit the one ton
u- bolts. Took about a half hour and worked out great.
Steve
'49 3800
'52 3600
'57 3100
You might also consider using the 1/2-ton springs.
Ghostrider how did you make out with connecting the steering up? I cannot remember off the top of my head what the difference was between the 3/4 and 1/2ton Axle other than possibly bigger Brakes?
If for some unknown reason, like I am cheap right now, the brake lines compatible anybody know?
The 1/2 ton springs are shorter aren't they?
Apprentice
Apprentice
I have another goofy question.... are the 3/4 axles different than the 1/2 ton? Will the hubs interchange?
The kingpins need to be redone on my 1/2 ton axle. Thinking about rebuild an axle/steering setup on an axle outside of the truck and then swapping it in.
The truck is my daily, so downtime is not practical.
Scott
http://waywardgarage.com
1957 Chevy 3100
'47-'52 1/2, 3/4 and 1 ton axles should all use the same drag link.
To install your 1/2 ton axle in the 1 ton, all you should have to do is the same
procedure I described earlier for the swap I did.
Steve
'49 3800
'52 3600
'57 3100
Yes, they are different. The hubs will not interchange.
Steve
'49 3800
'52 3600
'57 3100
Great... Over the weekend I picked up a front end from a 1/2 ton. The guy I got it from used to have about 5 he said until Old Navy bought them up. He kept this one truck that had a strange telephone box setup on it. Never saw anything like it before. That was really neat.
Hopefully in the next week or so I can start working on getting the new one in and the old one out.
New question, I was looking at wheels for the truck and noticed that the list said load was 1500lbs. Should I be concerned about the load numbers or not since I will never use the 1 ton to carry anything other than me?
