1 members (KEVINSKI), 160 guests, and 2 robots.
Topics128,108
Posts1,056,230
Members48,436
#582498 10/11/2009 11:07 PM
Fender is off the truck while fitting a patch panel. What should I apply to the inside of the fender. Undercoat? POR15?
Suggestions please.
"Happiness equals reality minus expectations" - Tom Magliozzi
There are several products you can use under your fender. One that is preferred is Linex bed liner. It protects the under side from rust, but it also prevents "stars" in the paint from forming on the top side of the fender. Stars are the result of rocks being thrown against the fender.
Another product is an under coating By 3M. It comes in an aerosol can. One can will provide about 3 coats. After it cures, you can either leave it black or paint it.
Another idea that most people use is just paint it with tractor paint that you get at Tractor Supply. It's tough paint and safer than POR-15. And a lot less expensive.
Frank Cox
Cox Custom Cars
No better smell than that of fresh paint. I've been building and painting cars/trucks for 47 years. Not gonna stop now.
http://www.coxcustomcars.com/
Out of all the stuff I've seen applied under body this one beats them all for looks, performance and application,3m Body Schutz.
http://solutions.3m.com/wps/portal/3M/en...RglVW64JTJ2DRbl
Or you can try this one but you may have to past the ulr:
http://www.autobodytoolmart.com/search/search.aspx?keywords=3m+body+schutz&s_kwcid=3m%20body%20schutz|3817924265&gclid=CKaAh8iTt50CFR4eDQodlWTFiw
Denny Graham
Sandwich, IL
Denny G
Sandwich, IL
Line-X (or an equivalent bedliner with a lifetime guarantee) goes on hot and ends up about .075" thick. The weight of the fenders nearly doubled and the reduction in road noise was incredible. I paid $100.00 for each fender and would do it again.
You Tube
