0 members (), 40 guests, and 2 robots.
Topics128,030
Posts1,055,428
Members48,422
#58235 03/24/2006 3:07 AM
Junior Member
Junior Member
How do the cam to crank marks line up for timing. I have a letter "V" and "O" on the gears. Also I have hydraulic lifters. Does this mean it's a car or truck engine.
#58236 03/24/2006 3:54 PM
Hey Cooch53,
What engine are you trying to line the marks up on?
Jon
#58237 03/25/2006 1:36 PM
Junior Member
Junior Member
Jon
It's a Chevy 235. 1960 era.
#58238 03/25/2006 2:37 PM
Use the old gears(if you still have them)to match the marks up in relation to the keyway groove.I think you will find it is the "O" marks.After you install the cam,you can check yourself by turning the engine clockwise and #1 or #6 intake valve should start to open.The cam turns at 1/2 speed to the crank.#1 and #6 are up at the same time.The top of the exhaust stroke or the top of the intake stroke.
Wanted Good Woman:
Must be able to cook , clean , sew , tune engines and polish trucks. Must have old Stovebolt and garage. Please send picture of old Stovebolt and garage.
#58239 03/25/2006 3:49 PM
If the engine has hydraulic lifters, is was originally an automobile engine.
Your cam gear is most likely fiber (non-metallic); truck engines had a metal (alloy ?) gear. Either cam gear may be used on either engine.
