1 members (NJC), 62 guests, and 1 robot.
Topics128,089
Posts1,056,004
Members48,430
#581792 10/09/2009 7:43 PM
Somewhere along the line, I was told to set my gas pressure at 10 psi, I just watched a Miller video that said 20 - 30 psi.
Am I way low? Maybe that's why my fender work looks so (expletive deleted).
"Happiness equals reality minus expectations" - Tom Magliozzi
Jim Bow #581814 10/09/2009 8:48 PM
My pal Jeremy does all the welding, but I have noticed that he has ours set on between 15-20 all the time. He can really lay a nice bead.
1953 Chevrolet 3600
Fried Green T'mater (Vern)
Caution: Political Statement
Jim Bow #581815 10/09/2009 8:48 PM
I'd say you're way low. 20 to 25 CFH (not PSI) is a good starting point. Of course Miller should know what they are talking about, but you probably won't need the flow rate as high as 30. Try some different settings to see what works best for you. Practice on scrap first!
Steve
'49 3800
'52 3600
'57 3100
I go with 25 on the gas regulator my hobart handler 135. 10 is too low and will give you poor penetration and not much sizzling bacon sound...
Jim Bow #581914 10/10/2009 1:30 AM
15-20 is perfect unless it is being blown away ie door open furnace blowing fan sucking all these things may take the gas from the welds and u will need to up press otherwise just a waste
I use 25 works good for me, I have Hobart 140 Mig welder
Ganesh
Thanks for the tips, I just picked up a Mig Master flowmeter on Ebay for $25. I think I'm supposed to be looking at 5 cubic feet per hour.
Jim Bow #582045 10/10/2009 12:53 PM
"I think I'm supposed to be looking at 5 cubic feet per hour"
Jim,
As I mentioned previously, a good starting point for your gas flow rate is 20 to 25 CFH. (cubic feet per hour)
Steve
'49 3800
'52 3600
'57 3100
Also make sure you have the gas tip on the gun and the polarity set correctly for welding with shielding gas. It is opposite polarity of flux core. My gun came with a plastic flux tip and a copper gas tip. I forgot to switch once.
Paint & Body Shop moderator
As you will find in my "Basics of Basics" on MIG welding, (Click here for the Basics)
"25-30 cubic feet per hour or 3-4 PSI." This is right from the AWS (American Welding society). First things first, does your MIG have a "Flow" meter measureing guage or a PRESSURE guage?
If it's measureing flow set it at CFH or is it pressure at PSI?
And I just noticed in my article it says cubic feet per MINUTE instead of HOUR! I'll have to correct that.
Anyway, look at your guage and see what it says you are measuring.
Brian
1948 Chevy Pickup
Chopped and sectioned
owned since 1974 when I was 15.
Thanks Brian,
I printed your article out for my shop notebook.
