1 members (TooMany2count),
81
Mod | | | Forums66 Topics128,126 Posts1,056,354 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2003 Posts: 218 Shop Shark | | Shop Shark Joined: Feb 2003 Posts: 218 | Do any of you know if the bellhousing bolt pattern would be the same on the 55-57 cars and a 66 C10 with a 250 I6. I'm hoping to use a trans from one of the cars...three speed manual. | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Yes, the pattern is the same.
Bill Burmeister | | | | | Joined: Apr 2005 Posts: 2,098 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,098 | The trans will bolt up but that year car transmission is about 5" longer than your 66 truck trans. The exception would be OD transmissions which are the same length. You could use the tail housing and mainshaft from your truck with the 57 trans. They have the same internal components. Fred
