3 members (GRNHydra, rfs56trk, Ole49GMC), 152 guests, and 1 robot.
Topics128,076
Posts1,056,280
Members48,441
Ok I've found my 4 turn wires,pilot wire,and "X" wire.What I need to know is what are my other 2 wires are for? My switch is a grote 966-7.
1953 Chevy Two-Ton
More pix on Photobucket
Be careful calling yourself a expert,because an "EX" is a hasbeen and a"SPERT" is a drip under pressure.
One will be brake light in. I don't know what an 8th wire would be for.
You can trace the wires using my Tech tip.
At two o'clock this morning I slapped my forehead DUHHH!!
Brake switch and feed from flasher.Thanks Cletis.
1953 Chevy Two-Ton
