1 members (JW51),
98
Mod | | | Forums66 Topics128,055 Posts1,055,782 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2009 Posts: 50 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2009 Posts: 50 | Its to my understanding that the wire going to the coil, brings the voltage to the coil down to the 9volts. It appears to be a special resistance wire? Anyways, is there a way to get rid of that wire and still only have 9volts going to the coil?
65 c20 250 I6 | | | | | | ZooKeeper Unregistered | | ZooKeeper Unregistered | Ballast resistor is the only way that I know of. You have to remember though you truck starts on 12volts & runs on 9volts. If you use a HEI dist you need a full 12volts for it..Joe | | | | | Joined: Aug 2009 Posts: 50 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2009 Posts: 50 | i know thats how its supposed to work. My truck only gets 9v during starting as well. so far hasnt been a problem and it starts and runs great. | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | you can use an internally resisted coil
Bill | | | | | Joined: Feb 2003 Posts: 218 Shop Shark | | Shop Shark Joined: Feb 2003 Posts: 218 | If you go to that HEI you will need a full 12 volts | | |
