Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
4 members (NJC, 1955 1 Series, Wayne67vert, 1 invisible), 141 guests, and 3 robots.
Topics128,281
Posts1,058,471
Members48,490
#580807 10/06/2009 12:59 AM
Its to my understanding that the wire going to the coil, brings the voltage to the coil down to the 9volts. It appears to be a special resistance wire? Anyways, is there a way to get rid of that wire and still only have 9volts going to the coil?
65 c20 250 I6
trevota #580826 10/06/2009 2:00 AM
Z
ZooKeeper
Unregistered
ZooKeeper
Unregistered
Z
Ballast resistor is the only way that I know of.
You have to remember though you truck starts on 12volts & runs on 9volts.
If you use a HEI dist you need a full 12volts for it..Joe
#580914 10/06/2009 8:11 AM
i know thats how its supposed to work. My truck only gets 9v during starting as well. so far hasnt been a problem and it starts and runs great.
trevota #580953 10/06/2009 2:46 PM
you can use an internally resisted coil
trevota #581197 10/07/2009 3:14 AM
If you go to that HEI you will need a full 12 volts
