7 members (cmayna, dt235sd, baldeagle, 1955 1 Series, NJC, 2 invisible), 93 guests, and 6 robots.
Topics128,016
Posts1,055,337
Members48,419
#5802 10/31/2004 8:06 AM
Apprentice
Apprentice
I'm getting close to installing my IFS. The instructions I have say to mock up to the desired frame rake. Problem is I really don't know how much of a rake I should go with. Anyone out there have any ideas a good rake position (as fare as degrees)? All the hotrod sites say a 3 degree rake is good. I just don't want to end up looking like a stink bug driving down the street.
Everything you know is wrong.
#5803 10/31/2004 3:31 PM
It depends on how ridiculous you want to look. Old trucks were designed to run level. The lines don't look right with the body at some foolish-looking angle. You don't get any gas mileage advantage trying to run one downhill all the time.
#5804 10/31/2004 5:00 PM
Z
Z Offline
I used a TCI MII IFS with a 2" drop spindle, if I were to do it again I would forgo the 2" drop and just go with the standard spindle.
http://community.webshots.com/user/zeker6
See Zeke's AD, it is a little low in the front with 16X7 rims front 16X8 rears and the lower A-arms level. Zeke
The Amish Connection
51 Chevy 1/2 ton 5 window,Vortec hotrod, no horse
#5805 10/31/2004 5:57 PM
I'm with Hrl--trucks are designed to haul loads--otta be level--rakes are for the garden or bikes if u gotta chopper orientation. grin
Buzz'n Half Dozen
#5806 11/01/2004 4:14 AM
If "rake" means your hind-end stickin' up in the air, then my '54 1 ton used to have "rake" right from the factory. But it looked nice and level with about 20 sacks of seed corn in the back...
#5807 11/01/2004 7:20 PM
easy guys some of us do like hot rod/street rod trucks! sbigelow what year truck are you building? most ifs set ups will lower the front 4". i hacve a 56 chev stepside i all ready played around with the stock leaf springs to give me 3.5" and about 3" in the rear. if i can get the same stance with the mustang II front it will be cool.the way i would do it is block up the truck 4" lower than it sits now.you can cheat some with tire heights too.
#5808 11/01/2004 9:50 PM
Apprentice
Apprentice
56 newbie, I have a 1950 1/2 ton. I am installing a TCI IFS. I opted for the stock spindles because everyone I spoke with said the 2" drop was too much. I am also replacing the rear leaf spring with a TCI leaf spring kit. I have a 77 firebird rear axle that I plan on installing. The cross member I am installing must sit level. I need estimate what my rake will end up being so my cross-member doesn't end up sitting uneven.
