| | | Forums66 Topics128,023 Posts1,055,370 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2003 Posts: 33 Apprentice | | Apprentice Joined: Jan 2003 Posts: 33 | I'm getting close to installing my IFS. The instructions I have say to mock up to the desired frame rake. Problem is I really don't know how much of a rake I should go with. Anyone out there have any ideas a good rake position (as fare as degrees)? All the hotrod sites say a 3 degree rake is good. I just don't want to end up looking like a stink bug driving down the street.
Everything you know is wrong.
| | | | | Joined: Feb 2004 Posts: 29,746 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,746 | It depends on how ridiculous you want to look. Old trucks were designed to run level. The lines don't look right with the body at some foolish-looking angle. You don't get any gas mileage advantage trying to run one downhill all the time. Jerry
| | | | | Joined: Aug 2001 Posts: 154 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2001 Posts: 154 | I used a TCI MII IFS with a 2" drop spindle, if I were to do it again I would forgo the 2" drop and just go with the standard spindle. http://community.webshots.com/user/zeker6 See Zeke's AD, it is a little low in the front with 16X7 rims front 16X8 rears and the lower A-arms level. Zeke
The Amish Connection 51 Chevy 1/2 ton 5 window,Vortec hotrod, no horse
| | | | | Joined: Mar 2001 Posts: 384 Shop Shark | | Shop Shark Joined: Mar 2001 Posts: 384 | I'm with Hrl--trucks are designed to haul loads--otta be level--rakes are for the garden or bikes if u gotta chopper orientation.
Buzz'n Half Dozen
| | | | | Joined: Nov 2003 Posts: 53 Member | | Member Joined: Nov 2003 Posts: 53 | If "rake" means your hind-end stickin' up in the air, then my '54 1 ton used to have "rake" right from the factory. But it looked nice and level with about 20 sacks of seed corn in the back... | | | | | Joined: Feb 2004 Posts: 41 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2004 Posts: 41 | easy guys some of us do like hot rod/street rod trucks! sbigelow what year truck are you building? most ifs set ups will lower the front 4". i hacve a 56 chev stepside i all ready played around with the stock leaf springs to give me 3.5" and about 3" in the rear. if i can get the same stance with the mustang II front it will be cool.the way i would do it is block up the truck 4" lower than it sits now.you can cheat some with tire heights too. | | | | | Joined: Jan 2003 Posts: 33 Apprentice | | Apprentice Joined: Jan 2003 Posts: 33 | 56 newbie, I have a 1950 1/2 ton. I am installing a TCI IFS. I opted for the stock spindles because everyone I spoke with said the 2" drop was too much. I am also replacing the rear leaf spring with a TCI leaf spring kit. I have a 77 firebird rear axle that I plan on installing. The cross member I am installing must sit level. I need estimate what my rake will end up being so my cross-member doesn't end up sitting uneven.
