4 members (Robert Crandall, farmallb, Steelonsteel, Rick Brown), 149 guests, and 5 robots.
Topics128,108
Posts1,056,239
Members48,437
#580368 10/04/2009 4:25 PM
New guy here. I know that some people "roll their own" but for those that have used a kit to mount an open rear diff what kit would you reccommend and why?
The easy way is hard enough.
I planned on using the ones from tractor supply, however someone stated that Chrysler/Dodge units are cheaper from the dealer.
I bought the parts for mine at a trailer supply store. For the u-bolts, bottom plates and spring cradles I think I spent no more than about $25 total.
Thanks guys, I look into trailer supply houses. Fasteddie, that is a nice truck. What front suspension is that?
Dave
Thanks for the compliment, Dave. Its a front suspension off a 1972 C-10. I have 2 1/2 " dropped spindles on it. I have had problems with the steering geometry and am currently trying to fit rack and pinion steering. I have a rack off a 98 F%@d Exploder and am trying to work out the details now. Thats one thing that makes this hobby fun--trying new things and experimenting. I have found there is no "one" way to do things, only what works. If I had it to do all over again I might have tried a Mustang II IFS, but I am too far into it now to stop my current plan. By the way, welcome to the 'bolt. I found out early that no matter what your question is or how stupid you might think it is, there is ALWAYS someone here to help!
I used the perches from Tractor Supply as well as the bottom plate for a 3" U-bolt. The U-bolts which were longer than those offered by the trailer places came from Azone in their "lowering" kits. However, I didn't use their aluminum lowering blocks.
I doubled the bottom plates and welded a 1/2" bolt across one end for my lower rear shock mount. Doubling probably wasn't necessary but I just didn't want any chance of a diff coming loose. Used a 1x2x6" chunk of bar stock to make a spacer under the perch. Drilled the spacer/spring bolt head so that I could move the diff back 1" to recentered my rear wheel in the wheel well. That let me use the stock driveshaft out of a shortbed S10 between my T5 and the Camaro diff. Figured the money saved on not having to get the driveshaft shortened paid for my mount hardware.
Dave
Webshot "Tips and tricks" and "Shoebox" Photo Albums
EXPERIENCE is the best teacher...but it gives the test first...and the lesson afterwards.
"What this generation tolerates...the next will embrace"
