3 members (Woodcmiami, Otto Skorzeny, JW51), 138 guests, and 2 robots.
Topics128,101
Posts1,056,181
Members48,436
#580196 10/03/2009 11:18 PM
Seriously - I have a number of friends - but only one of the even knows what a wrench is & he lives 8 freakin' hours away.
That said - If I provided the beverages & maybe some good tunes - could I talk one of two of my stove bolt buddies into helping me install my "new" door?
I imagine the removal is going to be easy enough - but holding the "new" door in place while I align the bolts is going to be a pain.
Unless - someone knows of a cool trick to install them w/o holding them a ft off the ground while trying to align the bolts????
1958 Chevy Apache 3200
bone stock 235
53k miles
3 on the tree
If I were closer I'd give you a hand. Alas, I'm on the west coast.
Mike
1958 Chevy 3200 Fleetside
1958 GMC 100 Wideside
Did you get free advice today? To donate to this site using PayPal is fast and EZ. Click here: http://www.stovebolt.com/office/thanks.html
Do you have a cherry picker? Thats what I used to support mine while I lined it up and installed the bolts. I've have learned to do almost everything myself because I get tired waiting for help to arrive.
Easy- - - - -c-clamp or wire a 2-foot piece of 2X4 to the pad of your floor jack, and use that to position the door where it needs to be. I've installed bunches of them that way when I was running a 1-man body shop. There are professional tools that do the same thing, but I was on a real shoestring budget. When it was necessary to get a job done, out the door, and paid for so I could go get a burger at the local greasy spoon, it was a real incentive to produce!
Floor jack and a chunk of RR tie works well, too.
Bill Burmeister
Necessity....The mother of invention!
Thanks for the tip Jerry,i'll be doing this too quite soon!
More pix on Flickr.
I have a nice air lift that can raise the door- I guess I can mess around & try ti keep it balanced while I start the bolts.
The shop manual said to start the bolts & close the door - then tighten & all will be in alignment.
I'm just not sure the door won't fall on my head while I'm doing this.
Thanks for the tips though -
bone stock 235
53k miles
3 on the tree
Done - Door installed! It wasn't as tough as I thought it would be. Just took a bit to adjust it to fit right.
Thanks for the tips.
bone stock 235
53k miles
3 on the tree
