| | | Forums66 Topics128,107 Posts1,056,221 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2009 Posts: 10 'Bolter | | 'Bolter Joined: Mar 2009 Posts: 10 | My first post so bear with me. My 53 3100 has a 54 235 in it. I just gave it a treat of reworked head (new stainless steel valves,new rods,)put her back together and can't keep a good spark. New coil,new points,new plugs still no spark! When there is spark she starts right up but the dwell flucuates, could it be as simple as a bad set of points? | | | | | Joined: Jul 2007 Posts: 293 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2007 Posts: 293 | Welcome aboard. I had the same problem on my '49 3100. Turns out it was a faulty ignition switch. Sometimes the switch worked, sometimes it didn't. Try running a #10 wire directly from the + battery terminal to the coil. This will bypass your starter switch and all the other loose connections under the dash. | | | | | Joined: Mar 2009 Posts: 10 'Bolter | | 'Bolter Joined: Mar 2009 Posts: 10 | Thanks for the idea but it did turn out to be a bad set of points right out of the box. Ole 53 purrs like a kitten now. | | |
