| | | Forums66 Topics128,012 Posts1,055,321 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2009 Posts: 134 Shop Shark | | Shop Shark Joined: Mar 2009 Posts: 134 | To make a long story short, can anybody tell what the side adjustment under the main cap in the rear end or called. I was trying to set the ring and pinion gear yesterday only to find the side adjustment caps or stripped. 1953 3100 216 engine orginial rear end.
Thanks Charlie
1953 5 Window 1994 Harley, Heritage Softail Classic 2006 Chevy Colarado I didn't say it was your fault, I said I was blaming you.
| | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy Charley, those large "nuts" are called the differential bearing adjusting nuts, be sure to check the threads in the housing and caps, if those threads are stripped then you must replace the housing/cap assembly, as they are machined as a unit, hope that helps | | | | | Joined: Mar 2009 Posts: 134 Shop Shark | | Shop Shark Joined: Mar 2009 Posts: 134 | Thanks Shop Shark,
Where can I get a set of these adjusting nuts? NAPA, AutoZone.
