7 members (32Fordpuchoptop, Nhluvstruck, 1955 1 Series, Steve 210, DHedrick, Bill Hanlon, 1 invisible), 153 guests, and 1 robot.
Topics128,114
Posts1,056,283
Members48,439
#579620 10/01/2009 9:36 PM
The bottom 10" of the rear of my left front fender has a rust hole in it. I bought a patch panel to weld in.
Should I remove the fender to fix it, or should I do it on the truck?
"Happiness equals reality minus expectations" - Tom Magliozzi
Jim Bow #579649 10/01/2009 11:57 PM
best to take it off, unless you want to weld the fender to the cowl wink
squeeze #579736 10/02/2009 3:37 AM
I did mine with the whole truck apart and I think that is easier.. That said if it was not already apart I think I would have done it in place. Taking the front fender off is not too bad. Lining it up when you put it back on can be problematic but not impossible.
Just be careful not to damage the cowl if you leave it on.
1953 3/4-Ton Chevy
More pix
If it can be built ... It can be fixed.
RB53
Have the fender on the truck when you weld it in. If you weld the patch in while the fender is off the truck you risk real problems with the door and step sill gap and alignment. That area is really prone to warping so you've got to be VERRRRY careful with the welder if you're going to butt weld it in.
Take it from me, I learned the hard way.
[b]1957 Chevy Big Window 3100[.b]
More pix in Picasa
It ain't broke 'til you can't fix it any more.
