1 members (baldeagle),
69
Mod | | | Forums66 Topics128,037 Posts1,055,467 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2007 Posts: 393 'Bolter | | 'Bolter Joined: Sep 2007 Posts: 393 | I remember reading about a tip to adjust points by attaching a piece of metal to the engine with a pointer pointing to the distributor. The distributor is moved to adjust the points (rather than turning the engine to get to the high point on the lobe) then the distributor is returned to the original position by lining up the 'pointer'; I thought it was on Stovebolt but I can't seem to find it. Has anyone heard of this tip and where it can be found? Thanks
It's a small world, but I wouldn't want to paint it.
| | | | | Joined: Jun 2001 Posts: 85 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2001 Posts: 85 | I have a '68 L-22 series 292 L6. [I can't speak for earlier engines] When my timing is set up right, with the distributor cap off, the Rotor points to the No. 1 cylinder when the engine is at top dead center.
Every 25 years I like to rebuild that 292 just for GP
| | | | | Joined: Jan 2000 Posts: 2,074 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 2,074 | That tip may be fine to get things lined up but you'll still need to check the dwell with a meter. | | | | | Joined: Sep 2007 Posts: 393 'Bolter | | 'Bolter Joined: Sep 2007 Posts: 393 | It wasn't meant to by pass setting the points, it was meant to make it easier to get to a high point on the lobe of the distributor shaft (i.e. turning the distributor rather than the engine)You would still check dwell and timing, of course.
| | | | | Joined: Jan 2008 Posts: 4,961 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,961 | Mark the setting on the octane selector where it is at so you can find it back. The octane selector is the marked thing on the distributor boss. Loosen the cap screw to where you can turn the distributor to where you are on top of the lobe. After you install the points, return the octane selector back to where it was in the beginning. | | | | | Joined: Aug 2008 Posts: 116 Shop Shark | | Shop Shark Joined: Aug 2008 Posts: 116 | Speaking of the octane selector...I've been pondering on that thing for a day or two. Isn't it really a means for setting maximum distributor advance? I mean, if the base timing is on zero (the pointer is pointing to the ball), and your octane selector is also on zero, then you have about 5 or 6 degrees of advance available to the distributor when you accelerate. If you move your octane selector from this base, you either increase or decrease the amount of advance (and therefore power) available to the engine...I'm askin' here...not tellin'...any other explanations? Jim | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | I think it was originally used to allow easy advance or retard adjustments (and return to "mark") due to varying grades of gasoline and or for travelling at different altitudes?
Tim | | | | | Joined: Oct 2005 Posts: 1,317 Shop Shark | | Shop Shark Joined: Oct 2005 Posts: 1,317 | As was mentioned, I suggested it so you could avoid having to turn the engine over. Have pics and discription of the stuff you need to fabricate to make it work in my WEBSHOTS "Tips and Tricks" album.
Dave | | | | | Joined: Sep 2007 Posts: 393 'Bolter | | 'Bolter Joined: Sep 2007 Posts: 393 | Fla54Chevy3100 Yes, Dave, that's what I'm talkin' abou'. I remember seeing it but couldn't remember where. Thank you!!
