4 members (Wayne67vert, MickeyP, Otto Skorzeny, Bill Hanlon), 176 guests, and 0 robots.
Topics128,106
Posts1,056,213
Members48,436
#579356 10/01/2009 3:03 AM
a 350 sbc with a 400 tranny in a 1940 1/2 ton . Will the engine fit witk out changing the stock fire wall? I am aware motor mts tranny brace etc. will be needed.
I have a 327 SBC in my '40 - fits just fine. I have a Mustang 2 front suspension - not sure of clearances with straight axle setup. You should go with a short water pump for rad clearance. I also have a " pusher " electric fan on the outside face of the radiator. Block hugger type headers fit between block and frame OK. Only minor issue might be relocation of steering linkage a little
1940 Chevy KC 1/2-Ton
Have a 400 sbc in mine.Used a short water pump and rams horn exhaust mainifolds.Every thing fit without fire wall mods.
