0 members (),
162
Mod | | | Forums66 Topics128,089 Posts1,056,441 Members48,443 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2009 Posts: 19 New Guy | | New Guy Joined: Sep 2009 Posts: 19 | Hello guys, I sorta asked this question in a different post but I thought i would just make a new one. I've got a 46 half ton Chevy, I would like to lower it about 2" all around. Nothing crazy, but just for a little better look. I have seen the drop axles, but I was wondering if there are spindles available... Also, I had read in a couple tech articles that people had removed a couple leefs to get the truck even lower, like a 5" drop all together. Can I just remove a couple leefs up front and get a couple inches lower?
Jason | | | | | Joined: Apr 2005 Posts: 381 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 381 | Not a good idea to remove a couples of leafs , you'll be bottoming out the front suspension on every bump you hit. You can go with the mono leaf front spring. It lowers the truck without loosing suspension travel. Also use a dropped axle. There aren't any dropped spindles for your stock truck axle. | | | | | Joined: Aug 2007 Posts: 1,859 Grumpy old guy playing with trucks, cars, and boats | | Grumpy old guy playing with trucks, cars, and boats Joined: Aug 2007 Posts: 1,859 |
| | | | | Joined: Sep 2009 Posts: 19 New Guy | | New Guy Joined: Sep 2009 Posts: 19 | Thanks for the suggestions.. Who sells the monoleaf setup? Are you saying I can just do that, or I should do the leaf setup along with the axle? I'm only wanting to go 2" or so.
Jason | | | | | Joined: Feb 2000 Posts: 769 Shop Shark | | Shop Shark Joined: Feb 2000 Posts: 769 | Most of the classic truck vendors carry monoleaf springs, or some other variation of drop springs.
FYI, I got my monoleaf from a local spring shop.
| | | | | Joined: Apr 2005 Posts: 381 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 381 | The mono leaf front spring will give you about a 2"( +/-) drop. Posies, has the spring, Chev's of the 40's , and I think Chassis Engineering might have it also. | | |
