Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
2 members (UtahYork, 50Chevy3100), 197 guests, and 4 robots.
Topics128,284
Posts1,058,523
Members48,490
#57948 03/19/2006 12:19 AM
Custom Title
Custom Title
I have a freshly rebuilt '54 235. After I set the valves and started it, I noticed that one of the pushrods isn't spinning. How do I fix it? Thanks
49 Chevy 3600
65 Chevy K10
66 International 1300 dually 4x4
46 Ford 1/2 ton
76 Tucker Sno-Cat 1642
96 Dodge 3500 Cummins dually flatbed x-cab 4x4
06 Jeep Wrangler LJ rock crawler
If you can't fix it with a hammer, it's an electrical problem
#57949 03/19/2006 1:15 AM
Apprentice
Apprentice
you might have a worn lifter or cam lobe in that spot,cam is not rotating the lifter as it should.
#57950 03/19/2006 3:45 AM
Check and see if you have the valve too tight on that cylinder. Ronnie
#57951 03/19/2006 5:43 PM
Did you follow the cam break in procedure, 1500 RPMs for 20 minutes? If not a lifter can quickly develop a wear pattern that keeps it from rotating.
It could be the lifter is turning but the pushrod is tight at the rocker ball, stopping only the rod from turning.
My Blog
