| | | Forums66 Topics128,284 Posts1,058,525 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#57948 03/19/2006 12:19 AM | Joined: Nov 2004 Posts: 267 Custom Title | | Custom Title Joined: Nov 2004 Posts: 267 | I have a freshly rebuilt '54 235. After I set the valves and started it, I noticed that one of the pushrods isn't spinning. How do I fix it? Thanks
49 Chevy 3600 65 Chevy K10 66 International 1300 dually 4x4 46 Ford 1/2 ton 76 Tucker Sno-Cat 1642 96 Dodge 3500 Cummins dually flatbed x-cab 4x4 06 Jeep Wrangler LJ rock crawler If you can't fix it with a hammer, it's an electrical problem | | |
#57949 03/19/2006 1:15 AM | Joined: Dec 2005 Posts: 20 Apprentice | | Apprentice Joined: Dec 2005 Posts: 20 | you might have a worn lifter or cam lobe in that spot,cam is not rotating the lifter as it should. | | |
#57950 03/19/2006 3:45 AM | Joined: Feb 2005 Posts: 68 Member | | Member Joined: Feb 2005 Posts: 68 | Check and see if you have the valve too tight on that cylinder. Ronnie | | |
#57951 03/19/2006 5:43 PM | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | Did you follow the cam break in procedure, 1500 RPMs for 20 minutes? If not a lifter can quickly develop a wear pattern that keeps it from rotating.
It could be the lifter is turning but the pushrod is tight at the rocker ball, stopping only the rod from turning.
See the USA in your vintage Chevrolet! My Blog | | |
