4 members (gswbbc, 32Fordpuchoptop, dwreills, Otto Skorzeny), 77 guests, and 2 robots.
Topics128,035
Posts1,055,447
Members48,422
#579418 10/01/2009 5:48 AM
I remember reading about a tip to adjust points by attaching a piece of metal to the engine with a pointer pointing to the distributor. The distributor is moved to adjust the points (rather than turning the engine to get to the high point on the lobe) then the distributor is returned to the original position by lining up the 'pointer'; I thought it was on Stovebolt but I can't seem to find it. Has anyone heard of this tip and where it can be found? Thanks
It's a small world, but I wouldn't want to paint it.
I have a '68 L-22 series 292 L6. [I can't speak for earlier engines] When my timing is set up right, with the distributor cap off, the Rotor points to the No. 1 cylinder when the engine is at top dead center.
Every 25 years I like to rebuild that 292 just for GP
That tip may be fine to get things lined up but you'll still need to check the dwell with a meter.
1946 1/2-Ton Chevy
It wasn't meant to by pass setting the points, it was meant to make it easier to get to a high point on the lobe of the distributor shaft (i.e. turning the distributor rather than the engine)You would still check dwell and timing, of course.
Mark the setting on the octane selector where it is at so you can find it back. The octane selector is the marked thing on the distributor boss. Loosen the cap screw to where you can turn the distributor to where you are on top of the lobe. After you install the points, return the octane selector back to where it was in the beginning.
Speaking of the octane selector...I've been pondering on that thing for a day or two. Isn't it really a means for setting maximum distributor advance? I mean, if the base timing is on zero (the pointer is pointing to the ball), and your octane selector is also on zero, then you have about 5 or 6 degrees of advance available to the distributor when you accelerate. If you move your octane selector from this base, you either increase or decrease the amount of advance (and therefore power) available to the engine...I'm askin' here...not tellin'...any other explanations? Jim
I think it was originally used to allow easy advance or retard adjustments (and return to "mark") due to varying grades of gasoline and or for travelling at different altitudes?
Tim
As was mentioned, I suggested it so you could avoid having to turn the engine over. Have pics and discription of the stuff you need to fabricate to make it work in my WEBSHOTS "Tips and Tricks" album.
Dave
Webshot "Tips and tricks" and "Shoebox" Photo Albums
EXPERIENCE is the best teacher...but it gives the test first...and the lesson afterwards.
"What this generation tolerates...the next will embrace"
Fla54Chevy3100
Yes, Dave, that's what I'm talkin' abou'. I remember seeing it but couldn't remember where. Thank you!!
