7 members (Deegs53, 78buckshot, Gray_Ghost, Wheelie, Otto Skorzeny, Gdads51, TUTS 59),
198
Mod | | | Forums66 Topics128,078 Posts1,056,022 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2009 Posts: 25 Apprentice | | Apprentice Joined: Aug 2009 Posts: 25 | can I use the electrolysis method to remove rust from cast iron exhaust manifold? | | | | | Joined: May 2009 Posts: 181 'Bolter | | 'Bolter Joined: May 2009 Posts: 181 | I haven't used electrolysis on cast iron, but I don't see why not. The problem that I forsee is getting all the water off of the porous cast iron after it's done de-rusting, if you don't get it all off, it will rust back up lickety split. I think sandblasting would be the best bet for this application
Bryan 1954 3104 235 "AD" L-6 3-on-the tree
| | | | | Joined: Mar 2004 Posts: 874 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 874 | I have used electrolysis on cast iron manifolds with good results. Photo Photo Photo | | |
