2 members (klhansen, 1 invisible), 88 guests, and 5 robots.
Topics128,126
Posts1,056,356
Members48,441
#578632 09/28/2009 10:16 PM
working on a 48 chevy that came to me with an offenhauser with dual one barrels.i'm hoping to find a linkage diagram to help sep up the choke's. any help is appreciated, thanks.
william quigley
You really only to choke one carb. I just ran the choke cable from the dash to the rear carb. I know I don't live where it gets real cold but I've never heard of anyone needing to choke both carbs.
George
Using a choke on a single carb (original Rochesters), as described by George, worked fine for me. Take out the choke plate from the carb not being choked.
Tim
Carburetion specialist
To each his own way of thinking.
Don't have a 6 at present; but have chokes on both carbs on my V-8. Works great, and will start (and run) in any temperature from -20 to 110. It is my shop truck, and sees winter driving.
Jon.
The Carburetor Shop
I have the choke on one carb. I am not happy with it. It doesn't seem to work as well as when I manually set both. As such, I have been too lazy and too busy to make them both operate. It does get cold up here.
Christopher
1950 1-Ton
"Rochester"
In the DITY Gallery
1949 GMC Panel Truck
1926 Model TT Truck
I am using one choke on my dual Carter W1 carbs, the rear one and it seems to work well.
1955 Chevy 3100
thank you all, as it turns out there is a clamp mounted on the side of the rear carb for the choke cable, it was an easy hook up and cold starting has greatly improved. can you tell me what is the advantage of now removing the choke flap from the front carb?
thanks again,
quigs
william quigley
Om mine, I just locked the choke open.
1955 Chevy 3100
hb32 #579086 09/30/2009 12:02 PM
Locking the unused choke flap open works fine. Removing the flap works fine (and there is never a concern that the flap might accidentally close even a little bit).
Tim
thanks again,
quigs
There is NO advantage to doing this; in fact, it is detrimental on a street engine. The choke plate acts as a straightening vane to straighten the eddy currents in the air which enter the carburetor.
Jon.
The Carburetor Shop
Yes, and in addition you want both carbs to be as identical as possible so they both feed the same amount of fuel at any vacuum/throttle position. Removing the choke plate changes that.
Paint & Body Shop moderator
